lumpy, low power bottom end
Discussion in 'Technical Help' started by megga, Sep 5, 2014.
  1. megga
    megga Member
    Jul 5, 2014
    10
    My Trophy 900 t reg has started getting lumpy low revs, after 4.500 rpm its ok. Was fine when I got it, but its not been ridden much (due to a bad shoulder) but I had taken it to a garage a while back (around a month-6 weeks ago) due to this problem, and it sorted it for a while, but took it out today and its awful. Problem is I have a biking trip to france on Tuesday, so no time to take it back to garage.
  2. ian
    ian Well-Known Member
    Aug 13, 2014
    23
    58
    From the mud people
    Sounds like blocked carbs with gunge. you would be surprised at how quickly petrol goes off now-a-days, theres so much additives to it.Also have a quick look at the vent on the tank to see if not blocked. You could try and fill it with higher octane petrol and go for a long ride to see if clears the carbs for tues??
  3. megga
    megga Member
    Jul 5, 2014
    10
    Gave it a strip and found a 3mm split in the vacuum hose, so all sorted now, thanks ian for you reply
  4. ian
    Aug 13, 2014
    23
    58
    From the mud people
    :upyeah::upyeah:
