Loctite On Brake Caliper Bolts? (speedmaster)
Discussion in 'America, Speedmaster & Rocket' started by M1Tommy, Jun 15, 2020.
  1. M1Tommy
    M1Tommy Member
    May 29, 2020
    54
    Arkansas, USA
    I removed my wheels, getting new tires.
    I removed the brake calipers to ease wheel removal.
    Question, should I Loctite (blue, I assume ) the brake caliper bolts when I reassemble everything? I did on prev bikes, but I found no evidence of Loctite on these.
    I tended to use Loctite on EVERYthing threaded on my Harley Davidson and old Kawasaki VN800.
    Opinions or advice?
    Tommy
  2. M1Tommy
    M1Tommy Member
    May 29, 2020
    54
    Arkansas, USA
    Ha!... good one!
    I was a bit surprised at how un-tight they were, and that no signs of Loctite were present.
    Thanks, Tommy
  3. Erling
    Erling Elite Member
    Dec 12, 2017
    1,123
    943
    Norway
    Personally I always do, but I'm a pessimist.
  4. M1Tommy
    M1Tommy Member
    May 29, 2020
    54
    Arkansas, USA
    I am inclined likewise. I've not heard/read any ill effects of it, no, "Ee-gads NEVER on a Triumph!".....
    Thanks, Tommy
  5. Rocker
    Rocker Elite Member
    May 1, 2016
    1,662
    Suffolk
    Copper slip to stop the bolts seizing and torque to the correct setting
    • Agree Agree x 6
  6. M1Tommy
    M1Tommy Member
    May 29, 2020
    54
    Arkansas, USA
    So your recommendation is non-sieze, as opposed to Loctite...
    I will read up on that, thanks!
    Tommy
  7. Rocker
    Rocker Elite Member
    May 1, 2016
    1,662
    Suffolk
    Yes mate non moving/stressed bolt which needs to be removed periodically
  8. Georgez
    Georgez Senior Member
    Nov 2, 2019
    389
    163
    Pacific North West
    And correct torque setting.
  9. M1Tommy
    M1Tommy Member
    May 29, 2020
    54
    Arkansas, USA
    Absolutely, I hear you well there.
    Tommy
  10. joe mc donald
    M1Tommy
    I use silicon on my bolts. Simply because it will stay there and the bolts do not loosen till you want them to. Used this method as long as I can remember even on classic Triumphs and BSA'S and Norton's and it works for me. I even use it to seal exhausts and they stay that way till I want to remove them.
    Regards
