Linkage Bearings 2011 Speed Triple
Discussion in 'Technical Help' started by Foxy1, Apr 7, 2020.
  1. Foxy1
    Foxy1 Crème de la Crème
    Sheffield
    Eyup chaps. I've greased t'bearings int bottom of mi shock, and both ends of t'dogbone. Is this(see pic) a bearing, or just a bush?
    Cheers.
    #1
  2. dilligaf
    It’s a bearing :)
    The centre piece should come out and you’ll find needle rollers inside :)
    If it was just a bush it wouldn’t have seals :)
    #2
  3. Helmut Visor
    I am so glad you answered that sensibly, I was moments away from a "No, this is a bush" inappropriate photo :joy::joy:
    #3
  4. dilligaf
    Bugger...:confused:....missed opportunity :(
    #4
  5. Foxy1
    Sheffield
    Tha slipping, Dilly.....:rolleyes:
    #5
  6. Foxy1
    Sheffield
    Oh, and thanks, by the way.
    #6
  7. Foxy1
    Sheffield
    I only asked because that one doesn't move. Will knock it out toneet.
    #7
  8. Yorkshireman
    Knock what out Foxy, what tha dus in’t shower is thy business mate.;)
    #8
  9. dilligaf
    Should just push out :confused:
    #9
  10. sean quinlan
    sean quinlan Well-Known Member
    cork ireland
    just had to change the dog leg on my sprint it was full of grease but sized solid the grease was to heavy so blocked up the holes it was supposed to flow through so make sure you use a light weight grease
    #10
  11. Foxy1
    Sheffield
    I use Century Lupus A3 bearing grease.
    #11
  12. Foxy1
    Sheffield
    I want to change the bearings on mi dog bone. Anyone know what bearings, seals and bush, I need, and where from? I presume a Triumph dealer will be a lot more expensive.
    #12
