I've found a few brief references to the LedPERF LED kits on this forum but no definitive answer to the question 'is it any good?'. As many owners of the water cooled Bonnies will know, the head light is bollox if you actually want to see where you're going at night on unlit roads. In fact it's downright dangerous if you choose to travel at more than walking pace and want to avoid badgers, hedges and other bits of nature. So I've been thinking of moving from halogen to LED. The LedPERF bulb kit is around £45. The blurb with the all-in-one kit says it incorporates all necessary electronic components and is simply plug&play. Has anyone fitted it and if so can it be recommended or condemned?
Went to all LED on my older Triumph [2002]. Best move I have made in a while.Triumph headlights have always been crap. ...J.D.
Ledperf Bulb Kit is designed to provide an efficient and brighter lighting system for your motorcycle. The kit includes two bulbs and a plug & play wiring system that makes installation easy and fast. The bulbs are waterproof, shockproof, and vibration resistant, so you can be sure of their durability. You can go for this and enjoy the improved visibility and lighting performance with this bulb kit!
