Led Indicator Problem
Discussion in 'Bonneville' started by Tallpaul, Feb 3, 2021.
  1. Tallpaul
    Tallpaul Noble Member
    Apr 7, 2019
    607
    393
    Kidderminster
    2003 T100 790.
    I have just fitted a tail tidy and 4 led indicators, together with a compatible, adjustable flasher unit. Removed the alarm and the bike starts fine, as before. Tail and brake lights all ok. Fuses all ok, no displaced wires. Indicators will not flash at any setting. I tried another flasher unit and the original, still nothing. All suggestions very welcome, please!
  2. Hubaxe
    Mar 25, 2020
    1,718
    Aix Les bains - French Alps
    Leds have a + and - and work only on the correct way.
    I would remove 1, and try directly on a battery to check the polarity.
    About adjustable flasher, I had an issue having the wrong layout model. I had a JL02 and Triumph needs a GL02.
    But that comes after testing the led polarity
  3. Cyborgbot
    I was going to suggest that...
  4. Hubaxe
    Mar 25, 2020
    1,718
    You were about to be right then :p
  5. Tallpaul
    Apr 7, 2019
    607
    393
    Kidderminster
    Thanks both. Another trial in the morning!
  6. figwold
    figwold First Class Member
    Dec 12, 2016
    634
    England
    But aren’t they reversed on the continent?;)
  7. Cyborgbot
    Silly boy, they go allumé et éteint over there!
  8. Hubaxe
    Mar 25, 2020
    1,718
    ours are "eteint" then " allumé" :confused: hmm
  9. Tallpaul
    Apr 7, 2019
    607
    393
    Kidderminster
    Well done my friend. I have substituted the flasher relay and I now have 4x working indicators. I had to remove the idiot light from the dash, because it was making all 4 flash together. I now need to find a way to give me a warning light. I'm guessing that if I fit an LED, it will now only flash for left OR right?
  10. Hubaxe
    Mar 25, 2020
    1,718
    Happy that worked. I wonder why the dashboard light shortcut the blinker button.
    I'll try to understand with the schematic.
