Tiger 800 K-tech For Springs For A Tiger 900 Gt Pro
Discussion in 'Tiger / Explorer' started by SpokaneJim, Oct 26, 2025.
  1. SpokaneJim
    SpokaneJim Well-Known Member
    Oct 11, 2025
    66
    Spokane, Washington
    I have a 2021 Triumph Tiger GT Pro. I rarely take it off pavement and it has Metzler Tourance Next tires.
    If I use the front brake in a turn the bike doesn't respond well. The front end dives and it feels bit unhinged at the handle bars. On my 17 FJR ES I don't have this problem. Granted using brakes mid turn is less than but I have been riding FJRs for 15 years so bad habits are hard to break and who doesn't over cook a turn once in a while?
    The KTech springs are straight rate (6.5Nm) std Tiger is 4.75Nm, so it is much stiffer.
    The shock preload is in the minimum position even with luggage and it seems fine but the front end seems soft. I weigh 230 pounds before riding gear.
    As the front end feels softer than the rear the KTech spring might bring some balance to the motorcycle.
    Anybody try these on the Tiger?
    Any suggestions and comments are welcome.
  2. Dickie
    Dickie Active Member
    Jun 8, 2016
    128
    Tadcaster, North Yorks
    I read about the soft front & experienced it on a test ride, but after getting my 2025 900 GT Pro I put the forks in the Sport setting & it feels good.
    From memory its both adjusters 2 clicks out from fully closed.
