Sprint GT Fuel Gauge "stuck"
Discussion in 'Sprint & Trophy' started by Aidan, Mar 17, 2022.
  1. Aidan
    Aidan Well-Known Member
    Dec 31, 2018
    185
    Went for ride today. Was full when I went out and bars dropped as normal. Filled up and the bars usually go all the way to top after a few miles. However, gauge is stuck on the number of bars it had when I filled up. Disconnected battery but made no difference. Anyone got any ideas?
  2. capt
    capt Elite Member
    May 8, 2016
    3,051
    western Australia
    Shake the tank ? Sensor float ? Probably stuck !
  3. Aidan
    Dec 31, 2018
    185
    By way of update - new sender arrived. Another Triumph rip-off (£80). Anyway, fitted it and still not working. Plugged into Tune ECU and did a reset and now all fine.
  4. Macduff
    Macduff Well-Known Member
    May 21, 2020
    49
    Aberdeen
    What type of fuel did you use?
    I've found that filling my ST with E10 causes problems with the gauge under reading. If I use super unleaded (E5), it reads correctly
  5. Baza
    Baza Elite Member
    Jul 25, 2020
    4,990
    Amazing Grace
    Could this be due to the two fuels having different specific gravities? After all the sender unit is basically a mechanical device, isn’t it? I ask because I’m still in analogue mode from my old Ducati and are not entirely familiar with the electrickery on these modern machines yet.
  6. Macduff
    May 21, 2020
    49
    Aberdeen
    Yes, I'm assuming it's something like that.
