Front Brake Binding
Discussion in 'Newbies Hangout' started by Lye 767, Nov 25, 2021.
  1. Lye 767
    Lye 767 New Member
    Nov 25, 2021
    London
    Hi all I am a newbie on this site. I currently own a 900 Trophy. I would like some help because the last time I went out the front brake started binding and I come to a stop. Can any inform me if the front brake master cylinder has two holes at the bottom of it or just one out let?
  2. Lye 767
    Lye 767 New Member
    Nov 25, 2021
    London
    This is because after inspection of the master cylinder I can only see one that Goes to the piston. There is a second start of a hole but it doesn’t go to the piston in the master cylinder.
  3. Helmut Visor
    Hi Lye :cool:
  4. Lye 767
    Lye 767 New Member
    Nov 25, 2021
    London
    Can you please help to the technical post forum.
  5. Lye 767
    Lye 767 New Member
    Nov 25, 2021
    London
    I cannot see how to get there
  6. Helmut Visor
  7. Yorkshireman
    Hello Lye, what’s your concern regarding how many holes the master cylinder has got, if you’ve got a binding front brake how are the holes in the bottom affecting this situation? Have the brakes been worked on recently, new levers, or pads etc? Some more info will help us to help you.
  8. sprintdave
    1,653
    You probably just need to clean the crap from round the piston and/or the pads. I wouldn't be fussed about the hole
  9. David Cooper
  10. Wessa
    Hi and welcome….
  11. Lye 767
    Lye 767 New Member
    Nov 25, 2021
    London
    Thanks
  12. Lye 767
    Lye 767 New Member
    Nov 25, 2021
    London
    Thanks
  13. Lye 767
    Lye 767 New Member
    Nov 25, 2021
    London
    Today I cleaned out the second hole in the bottom of the master cylinder. This has solved the problem of the binding .By releasing the pressure on the callipers when the lever is fully released.
  14. capt
    capt Elite Member
    May 8, 2016
    3,052
    western Australia
    With the age of the bike , it's a good idea to clean up the calipers as well !
  15. Lye 767
    Lye 767 New Member
    Nov 25, 2021
    London
    I did replace all the pistons and seals on the callipers. This because they were corroded.
  16. Dartplayer
    Hi Lye and welcome to the forum :cool: good to hear you sorted the issue, looking forward to seeing your ride :p
  17. Lye 767
    Lye 767 New Member
    Nov 25, 2021
    London
    Yes will do in the spring only two days to ride the bike now before it is put away for the winter.
