I have a solid amber warning light on my trimpth street triple, I just changed the battery and now the bike is starting, I did try and jump start it a few times before changing the battery, is it normal after changing the battery for this light to come on? Any tips?
If it's the same as the T595 it goes off after a few heat/cool cycles, (if I remember correctly), or reset it with Tune ECU.
Thank you I'm going to take it for a run as it's not been started for months, hopefully it goes away, if not I'll take it to a garage as I'm new to this
Hi Bradley, and welcome in From what I've read on here you will need to do 3 complete heat/cool cycles ie. take it up to operating temp, let it fully cool to cold x3 if that doesn't work I'm out of ideas but there will be plenty of other suggestions coming in then
