Engine Overheating And No Fan
Discussion in 'Technical Help' started by Kennymact, Dec 11, 2017.
  1. Kennymact
    Kennymact New Member
    Dec 10, 2017
    Nz
    Hi everyone. A newbie here and my first post is a technical problem. Engine overheating and the fan failing to come on. I have checked fuse and changed the relay and bypassed the fan to ensure it runs and the eng temp sensor remittance is in spec so have run out of fault diagnosis. Any one have anything else I can check to find out why the fan is not kicking in ? Cheers
  2. Tucker 1963
    Hello and welcome to the nut house you should fit right in.
    Someone will be along shortly too help.
    Tucker:rolleyes:
  3. capt
    capt Elite Member
    May 8, 2016
    3,051
    western Australia
    Is the thermostat opening ? Take it out drop it in a pot of water on the stove on high see if it opens. If it doesn't that will be your problem.
  4. Kennymact
    Dec 10, 2017
    Nz
    It’s taking about 20 mins to overheat soni think if it was defective it would either happen really quickly or very slowly. Also the fan should still have kicked in. I read somewhere today that previously they have had an issue with the temp sensor not working so I will replace that first. I ll look at the thermostat tomorrow as that’s another tick in the box. Cheers
  5. thebiglad
    Hi Kenny, what model/what year of Triumph have you got ?
  6. Kennymact
    Dec 10, 2017
    Nz
    Cheers. Checked that and ensured there was coolant in both. Maybe an airlock so will bleed it tomorrow
  7. Kennymact
    Dec 10, 2017
    Nz
    #7 Kennymact, Dec 12, 2017
    Will let you know how it goes. I suspect the temp sensor in the cyl head and might order one just in case. Very irritating when everything passes the test but still the fan won’t kick in.
  8. sprintdave
    1,621
    lol, And the bike is a .............
    please excuse me is I missed it I have a cold and drinking whisky/honey etc to fix my throat.
  9. Kennymact
    Dec 10, 2017
    Nz
    Sprint 1050 2005
  10. stevethegoolie
    stevethegoolie Elite Member
    Oct 16, 2014
    2,455
    East Riding of Yorkshire
    Better than paracetamol any day!!:grinning::grinning::yum
  11. Kennymact
    Dec 10, 2017
    Nz
    So have bled the cyl head bleed point. Put fuel tank back on but can only find one brown plug to fit. Now have the yellow Eng light on dash. What have I missed ?
  12. Kennymact
    Dec 10, 2017
    Nz
    yaaay. Fans running at six bars. Still have the yellow warning light on dash. Good but still an issue. So that tells me air lock and all good now it s been bled. I m hoping I’ve missed an electrical connection somewhere. So one brown Big elec plug and a small one then one vent hose and the fuel line. What’s missing ? 2005 sprint.
  13. Sprinter
    Three hot cold cycles should remove engine light if you have done everything corretly.Heat bike till fan then off cool repeat
  14. Kennymact
    Dec 10, 2017
    Nz
    T
    Most excellent. I ll report back
  15. Kennymact
    Dec 10, 2017
    Nz
    Cheers. Why does that happen and what triggers the error ? Ecm or a plug disconnect ?
  16. Red Thunder
    Red Thunder Crème de la Crème
    Dec 2, 2014
    2,034
    High Wycombe
    If you turned on the ignition (not necessarily starting the engine) without the brown tank plug connected it would trigger the fault.
    As mentioned 3 hot/cold cycles and the error should clear
    Glad you got it sorted yourself
