Engine Check Light Daytona 675 2007
Discussion in 'Newbies Hangout' started by Monty 675, Nov 25, 2019.
  1. Monty 675
    Monty 675 New Member
    Oct 28, 2019
    15
    Gainsborough
    I was just wondering if you can help I have recently purchased a 2007 daytona 675 and I have an engine check light on the bike seems to run fine but light stays on it did go off once but its back on I belive the bike was stood for a while before I purchased it and the exhaust seems to go quieter at times was wondering if any one could help with this issue please thanks
  2. Bad Billy
    Sorry unable to help on your issue, but someone will.
  3. StrippleMont
    StrippleMont Senior Member
    Nov 5, 2016
    349
    220
    Round your way!
    Welcome to the madhouse.
    Could be that the battery has been disconnected at some time.
    Had the same on a Stripple I had, try 3 cold to hot restarts, should clear it...... if not take it to your local "Stealer"
  4. Wessa
    Hi and welcome....
  5. Don the Don
    Hi and welcome
  6. Helmut Visor
    @Monty 675, mate everyone will now welcome you into the forum again as you have posted this in the Newbie Hangout ;);) Might I suggest you post it in the Technical Help section or the Daytona section that way you will probably get a better response to your question :cool::cool:
  7. dilligaf
  8. joe mc donald
    Monty 675
    Welcome to the family. Yes you probably need to do up to three starts about 12 minutes or two starts then take the bike for a run. Should reset the warning light.
    Regards & Ride Safe
  9. David Cooper
    Hello and welcome to the forum Monty.
  10. Tiglet
    Hello Monty and welcome to the forum :)
  11. Claudio
    Claudio New Member
    Mar 30, 2020
    Alkmaar
  12. Claudio
    Claudio New Member
    Mar 30, 2020
    Alkmaar
    #12 Claudio, Mar 31, 2020
    Hi, their is a actuator valve inside the exhaust.
    The actuator needs to see the valve fully opened. It could be that this valve is not opening entirely.
    The same issue happens of people put aftermarket exhaust witch have no valve at all. To get rid of the error with aftermarket exhausts you can buy a Servo Emulator..
    In your case i would try to open and close the valve manually, check if its smooth. Otherwise add some lubricant.
    I hope this helps!
