Electrical Problem
Discussion in 'Technical Help' started by geoffs, May 27, 2019.
  1. geoffs
    geoffs New Member
    May 27, 2019
    4
    surrey
    1961 650cc twin both spark plugs spark, then stay with a constant spark on both plugs help
  2. joe mc donald
    Geoffs.
    Welcome to the family. What electrical system are you using. As things like boyer have a wasted spark.
    Ride Safe
  3. Tricky-Dicky
    Dec 12, 2016
    2,441
    Norfolk UK
    #3 Tricky-Dicky, May 27, 2019
    And the problem is????? there is no way you will get a constant spark, as Joe says if electronic then it will be wasted spark and both plugs will spark together which is not a problem.
  4. Tiglet
    Hello Geoff’s and welcome to the forum :)
    I think more info is required :rolleyes:
  5. geoffs
    geoffs New Member
    May 27, 2019
    4
    surrey
    thanks for your reply both plugs have constant spark just with ignition switch on
  6. Yorkshireman
    Well I’m still not getting what your problem is. You are getting sparks at both plugs with the ignition on?
    What are you expecting?
  7. Tricky-Dicky
    Dec 12, 2016
    2,441
    Norfolk UK
    Can you define what you mean by constant?
  8. geoffs
    geoffs New Member
    May 27, 2019
    4
    surrey
    hi turn on ignition key , spark plug has continuous spark without turning the
    engine
  9. joe mc donald
    Geofs.
    That is a new one on me. Sparks without turning the engine. Going back to the ignition. What setup have you. OEM points and stator or has it been converted to something like boyer. The only thing it could be is a faulty electronic box. Its a hard thing to see in my mind. Is the spark continuous or intermittent. You got me scratching my head here.
    Regards
  10. Hamburg
    Hamburg Senior Member
    Dec 12, 2018
    788
    Oxford, UK
    It must be running electronic ignition, I can’t see how that could happen with traditional points and distributor.
  11. Tricky-Dicky
    Dec 12, 2016
    2,441
    Norfolk UK
    Yes got to be electronic...i would suspect a short in the hall sensor or the control box is fried.
  12. joe mc donald
    Hamburg.
    Would tend to agree with you there. Or its a demon bike.
    Regards
  13. geoffs
    geoffs New Member
    May 27, 2019
    4
    surrey
    Thanks for your advice ill be having another look at the weekend
  14. curly
    curly Noble Member
    Jul 3, 2016
    758
    Burton Upon Trent
    A man of few words
  15. Yorkshireman
    But many sparks!o_O
  16. Callumity
    3,362
    That’s the long & short of it!
  17. Yorkshireman
    Shocking :grinning:
  18. Adie P
    Adie P Crème de la Crème
    Jul 7, 2018
    3,703
    MID DEVON
    But bright?
  19. Yorkshireman
    Enlightening
  20. darkman
    A bad earth or shorted out low battery can cause this issue.
