Crankcase Oil Fill Level
Discussion in 'Technical Help' started by MoreCowbell, Jun 13, 2025.
  1. MoreCowbell
    MoreCowbell Member
    Apr 24, 2021
    New Mexico
    2016 Bonneville T100
    To set the oil fill level, should the bike simply be leaning on its kickstand, or placed vertical? The Maintenance Handbook doesn’t say and it makes a big difference in the sight glass !!
  2. joe mc donald
    Vertical. Fill it to the level run for a few seconds then let it settle and top back up to the level.
  3. MoreCowbell
    MoreCowbell Member
    Apr 24, 2021
    New Mexico
    Thanks for your response Joe. And I beg your pardon:
    In the Owner's Handbook (p.69), there is not a whisper about bike position. However, in the Service Manual (Lubrication System, p9.9), it says "The motorcycle must be level and upright when checking the oil level." I just caught that and stand corrected. And btw, I made a very nice jack for lifting and stabilizing the bike at any level. :cool:
  4. joe mc donald
    @MoreCowbell No problem. The second check when you have filled and ran then let it settle is i you have fitted the new oil filter when you run it the filter fills up and level adjusts a little. The wating is so the oil can return from places like the head and cams. Glad you are getting sorted and a good lift is a great asset.
  5. Baza
    Baza Elite Member
    Jul 25, 2020
    4,615
    Amazing Grace
    Depending on the orientation of the filter when fitted it can be pre-filled prior to fitting.
