Correct Con Rod Shells Help
Discussion in 'Technical Help' started by Chris050583, Jun 2, 2018.
  1. Chris050583
    Chris050583 New Member
    May 30, 2018
    Lincoln
    Hi All,
    Following my recent post I have manage to obtain the correct sizes as per the chart in the workshop manual so time to order my shells.
    On the World of Triumph website can any one tell me why there are to choices for each colour shell for the con rods, for example part no. PFKL1182138 is a red shell however part no. PFKL1197406 is also listed as a red shell.
    My assumption is that they are different in diameter to accommodate the different crank journals fitted to the later engine so if this is correct could any one tell me the correct ones to order for my 98 T595, Thanks
  2. Oldyam
    Oldyam Grumpy Old Git
    May 14, 2017
    612
    ireland
    You will need to contact them with your vin number to get the correct ones
  3. Chris050583
    May 30, 2018
    Lincoln
    Thanks Oldyam, thought that might be the case, just wondered if anyone had had any previous experience and could remember
