Compatible? Speed Triple Forks From 2011 On 2010
Discussion in 'Technical Help' started by Red Thunder, Jun 12, 2019.
Tags:
  1. Red Thunder
    Red Thunder Crème de la Crème
    Dec 2, 2014
    2,034
    High Wycombe
    Do you good folks know if the forks from a 2011 Speed Triple will work on a 2010?
    The 2011 forks have rebound and compression adjustment in both forks rather than one fork has rebound and the other has compression on the other as per the 2010
    Looking at upgrading my 2010 with 2011 forks and will service and respiring the 2011 forks fit my weight and style
  2. RSReggie
    RSReggie Active Member
    Apr 9, 2019
    114
    North West UK
    Quite a lot of differences including front wheel disk spacing and thickness etc .. my guess would be that you can't just change the forks. Maybe a whole front end might fit if headstock unchanged . I bought a 2011 wheel for my 2008 model and it was significantly different ..
