Brake Hose Clamp Question.
Discussion in 'Technical Help' started by Sprinter, May 17, 2019.
  1. Sprinter
    The previous owner of my bike was no slouch when it came to spending on aftermarket bits.
    When it came to fitting these parts not so much.
    I have spotted a cable tie keeping the master cylinder reservoir hose in place, so ordered a selection of hose clamps, and now ; I dont know if I should fit the one that says 8mm ,same as the hose, or. the smallest one I can get on, anyone have any thoughts ?
  2. Eldon
    Eldon Crème de la Crème
    A picture would help?
    Fit the size that matches the outer diameter, think more guide than clamp.
  3. Sprinter
    No pics tonight, thanks for the advice.
  4. Big Sandy
    Big Sandy WOOF! WOOF!
    Fuck off you nosy cunt
    I'd agree with @Eldon, just enough to hold the hose in place. Any tighter might cause them to snag, and looser may cause wear.
    Either way, better than a cable tie!
  5. Eldon
    I have, and more importantly felt, incorrectly mounted braided brake hoses!
    On the little (11 year old) lads Beta 80 we were doing some training. The rear brake hose around the rear shocker mount had a poor clip. It had worn through the braiding and the braiding turns into needles :tired_face:
    He was doing a log step incorrectly so gets off and let's me show him. Demo performed and me shouting "more back brake" he did which promptly bust the rear hose exactly where the clip is.
    That lesson £50 thanks, as that's what it cost me :rolleyes:
  6. alfie
    379
    213
    Bath, Zumerset
    I would avoid Jubilee type clips as they distort on tightening. I would go for fuel pipe clips as they tighten with consistent pressure all round the pipe.
  7. Sprinter
    download.jpg Went with these.
    I also got an even harder lever so chuffed.thanks for your help.
  8. Eldon
  9. Sprinter
    The ones used are more usual, no? The P-clip would be more secure for sure. Possibly belt and braces?
  10. Eldon
    Sorry are you securing the pipe to the reservoir?
    If so yes you are correct, I'm over thinking it and was meaning locating the hose path.
  11. Sprinter
    Yeah ok ,hose to reservoir sorry.
