bike running hot
Discussion in 'Technical Help' started by uktriumph, Jun 21, 2014.
  1. uktriumph
    uktriumph Member
    May 6, 2014
    My tt600 has an issue.
    It runs hot.
    ive just stripped the engine and did work on the head and it was all within spec.
    Put it all back together with new head gasket and its the same.
    Gets hot quicker than i think it should and on hot days will not drop below 100 unless your cruising at 50+.
    ive checked thermostat and thats fine but it gets hot just idling.
    Could there be a faulty sensor causing this?
  2. SteveJ
    SteveJ Super Moderator
    Aug 12, 2013
    524
    North Hampshire
    Sorry if this is a silly question and if you have checked this already but does a large amount of coolant go back into the overflow tank when it gets hot? If so then it might be worth replacing your radiator cap as these can go wrong.
    If you haven't done this I would suggest you get a new one (about £15 ) from you local dealer and try it first before you go any further.
    Cheers
    Steve
  3. uktriumph
    uktriumph Member
    May 6, 2014
    Thanks for your reply.
    I went for a ride yesterday and i noticed the temp guage jump up and down and then read a fairly constant 103-105 so i think the sensor may be faulty.
    I have ordered a new one so i will see how that goes first then post it up in here.
