Sprint Battery Zapped
Discussion in 'Sprint & Trophy' started by Duckadiledundee, Jun 21, 2020.
  1. Duckadiledundee
    Duckadiledundee Peasant First Class
    5,146
    High Peak
    What would completely zap a battery of all its power in five to fifteen minutes when the battery as had a full charge???
    The wife just reminded me that the reason I replaced the battery eighteen months ago is because I thought I had a dodgey battery as that would not hold a charge either...
  2. crispey
    sw london
    Jeez duck! Your bike is of the devils making, have you checked there isn’t a hex bag hidden in it somewhere? Maybe put a bit of holy water in the rad and add some Chrism to your oil!
  3. Duckadiledundee
    5,146
    High Peak
    It certainly makes you wonder mate...:eyes:
  4. Duckadiledundee
    5,146
    High Peak
    What about this bit being faulty...how do you test it to see if it's good or bad and what's a new one likely to set me back???
  5. freck
    freck Elite Member
    1,853
    Preston, Lancs, UK
    When you ripped your wiring loom to bits and pulled loads of ‘redundant’ wiring out, did you check that the charging system was still working after you’d put it all back together? o_O
  6. freck
    freck Elite Member
    1,853
    Preston, Lancs, UK
    Have a search through the forum to see if you can find Sprinter’s thread that had a list of checks to do to check the charging system.
    I seem to remember it listed what voltages you should get when running/ not running etc
  7. Duckadiledundee
    5,146
    High Peak
    Not specifically but the wife as reminded me that this was actually a problem before with the battery...
    Everything seemed ok visually...I mean it was all connected up properly and secure after all terminals and connections had been cleaned....
  8. Duckadiledundee
    5,146
    High Peak
    Also other than a visual check I can't do much else..I have no multimeter and would not know what or which kind to purchase as they all seem so different and vary hugely in price...plus not sure how yo really use one to find out if a parts working the way it should...
  9. freck
    freck Elite Member
    1,853
    Preston, Lancs, UK
    You can get a cheap multimeter for about £25 (there are cheaper but a 1p one on Amazon doesn’t make me think it’ll be much good :rolleyes:)
    Have a look at this one https://www.amazon.co.uk/AstroAI-Mu...9Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
    If you get one then there’s plenty of us here who’ll help you out with using it. :grinning:
  10. Smilinjack
    Smilinjack Crème de la Crème
    Aug 14, 2016
    1,442
    Nottingham
    As l've said before, got a multimeter and would happily have a cruise up to try and help you. Got a spare battery too. Have you got a Haynes manual? Pretty sure there are test readings for reg/rec etc in there. A good one from reputable dealer like Electrex will be £100-120 at a guess, Ebay tingtong stuff at a sixth of that price :)
  11. Duckadiledundee
    5,146
    High Peak
    Mrs Duck ordered it on her prime thingy....Be here tomorrow...I'm off work Wednesday so I shall undoubtedly be pestering you all for help...cheers lads...
    Thanks @freck
  12. Dozers Dad
    Dozers Dad Bushmills Chief Quality Controller
    That looks superb for the money Freck. I always tell people that a £20 DVM will do most jobs.
    But I've never seen one as feature packed as that for just a few quid more! :grinning:
  13. Duckadiledundee
    5,146
    High Peak
    Read my Haynes manual like its the bible :p
    I shall have a play on Wednesday with the multi meter and see what's going on there...I'm getting a bit despondent but don't want to break the bike and sell parts on Ebay just yet if I can avoid it as Mrs Duck is sort of recommended..:pensive:
  14. Smilinjack
    Aug 14, 2016
    1,442
    Nottingham
    Good luck dude :)
  15. Duckadiledundee
    5,146
    High Peak
    The wife says I should take you up on that offer...
  16. Smilinjack
    Aug 14, 2016
    1,442
    Nottingham
    It's entirely up to you. Happy to try and at least get you pointed in the right direction. I'm not Clive Woods but l'm not a complete cupcake either :)
  17. Duckadiledundee
    5,146
    High Peak
    I don't even know what the basics do nevermind the feature packed version :p
  18. Duckadiledundee
    5,146
    High Peak
    Ain't got a clue who Clive woods is and I best not talk about candy cupcakes...:p
  19. Duckadiledundee
    5,146
    High Peak
    Would have to convince the landlady your not a covid19 carrying robot out to destroy mankind but I shall work on it...:p
  20. Smilinjack
    Aug 14, 2016
    1,442
    Nottingham
    I'll mask up and wear gloves. I look better that way, as an added bonus :D
