Battery optimisers
Discussion in 'Technical Help' started by chiari1, Feb 17, 2017.
  1. chiari1
    chiari1 Elite Member
    Mar 19, 2016
    108
    wrexham , north wales
    #1 chiari1, Feb 17, 2017
    x
  2. MickEng
    MickEng Noble Member
    Sep 29, 2016
    1,805
    450
    West Yorkshire
    Totally agree with Jack, the Optimate or similar are clever trickle chargers and can be left permanently on when your bike is parked up, automatically adjusting the level of charge so your battery is always at an optimum operating condition
  3. crispey
    Bugger I bought the 3!!!
  4. GaryM
    Apr 28, 2016
    862
    Patna , Ayrshire
    Optimate 4 is what you want make sure you get one with a suitable lead for your tractor :D
  5. crispey
    #5 crispey, Feb 18, 2017
    Oh! I always thought you were 2 short not 1
  6. old git
    old git Well-Known Member
    Jul 4, 2016
    194
    Aberdeenshire, Scotland
    Both my T120 and my FJR1300 are constantly on Optimate 4's. FJR battery is 8 years old and still seems good as new.
  7. thebiglad
    I used to have an Optimate 3 but it died after relatively short service. I currantly :rolleyes: use an Aldi intelligent charger which has programs for bikes and cars and appears to work perfectly. Had it for about 18 months and totally faultless.
  8. crispey
    Quick question, I plug my optimiser 3 into the sae connector thats connected to the battery, the save light lights up then moves on to the charge light then on to the green test and maintain light. Should this glow solidly? I have had it connected for 24 hrs and it is still flashing, is this a problem or not?
    Ta
  9. thebiglad
    Hi Steve, it could be an indication of: either a faulty/defunct battery or the battery charger has died.
    My guess would be the battery is not holding the charge.
    I had an Optimate 3 that died on me so I now have (via Tigcraft) an excellent Aldi intelligent charger that only cost about £13 and has various programs for bikes as well as bigger batteries from cars and other vehicles.
  10. crispey
    Cheers Dave,
    It's definitely charging the battery. Would it be the alarm stopping it from reaching a constant full charge or even the tomtom rider dock? I shall unplug the latter. I am right in thinking that the green light should be constant at some point?
  11. GaryM
    Apr 28, 2016
    862
    Patna , Ayrshire
    http://accumate.co.uk/Optimate 3 Instructions.pdf
    My alarm doesn't stop mine from reaching a trickle charge state. The alarm is why I use one.
    Mine the optimate 4, so not sure if that makes a difference.
    At the top I put a link to the charger manual. It's easier to read than the booklet you get with it.
  12. crispey
    cheers, so it says the light should flash for the full 12 hrs, I can only assume its good then, doesnt say anything about a steady green light.
  13. thebiglad
    Hi Steve, I'm not at all pretending to know alot about Optimates, but I would have thought that it should, sooner or later, go steady green.
  14. crispey
    Cheers again! Took a reading shortly after charge and came out as 12.7 then 7 hrs later it's 12.58v. Alarm not fully armed
  15. thebiglad
    That suggests to me the fattery is bucked !!!
  16. RROB
    RROB Active Member
    Jul 9, 2016
    80
    Worcestershire
  17. SamC
    SamC Well-Known Member
    Feb 21, 2016
    177
    Hereford
    Optimate all the way!
