Another Quickshifter/gearbox Problem....sorry
Discussion in 'Speed Triple' started by XLRS SPEED TRIP, Jun 9, 2024.
  1. XLRS SPEED TRIP
    XLRS SPEED TRIP New Member
    Sep 1, 2019
    Victoria, Australia
    After reading all the Gearbox & Quickshifter threads I cant find an answer to what's going on with my 1050RS
    Riding along in 6th gear, with Cruise control on, it will suddenly flash to 5th gear on the display & shut off the Cruise (because it thinks I've changed down). Then display will go back to 6 after a little while.
    The quickshifter works perfect shifting down but not always up, esp. 4-5 & 5-6.
    Sometimes it is perfect, other times it will not shift gear till I pull the clutch or roll the throttle
    So I think it is a Gear Position sensor issue & quickshifter problem as well, but not sure what I can do about it
    Any ideas?
    went in for a Demo on a KTM 1290 SD GT....but the trade in for the Speedy is just too painful, offered $8K !
  2. Bolosun
    Bolosun Noble Member
    Aug 25, 2020
    531
    343
    Crewe/Cheshire
    It's more likely the speed sensors on the wheels not talking to each other. Make sure they are fitted properly and check the wiring.
  3. Marco Wikstrom
    Marco Wikstrom Active Member
    Sep 28, 2023
    233
    Albuquerque, New Mexico
    Are you accidentally touching the gear shift with your toe?
  4. Mark TGR9
    Mark TGR9 Well-Known Member
    369
    Rhuddlan North Wales
    I don't know with your bike whether you have the ability to go into the menu on the display but the quick shifter can be turned off I know this as my brother has had to have a new one luckily under warranty on his Tiger 1200 being nearly three years old with close on 10k I think if I remember it is listed as TCS on the menu if you can do this you can try this and at least rule it out or not if the issue continues I think the quick shifter is about £130 but it probably won't be just plug and play mr.triumph wants you to introduce it to the bike for a few extra of your English pounds or us dollars :mad:
