Another Problem Peeps.
Discussion in 'Triumph General Discussion' started by joe mc donald, Aug 26, 2025 at 6:11 PM.
  1. joe mc donald
    Just refitted the rear wheel in my Bonnie Scrambler after a tyre change. But when i torque up the wheel it locks. Everything is back in place as it came out. Any idea's.
    #1
  2. Boothman
    Boothman First Class Member
    Wigan
    Are you sure everything is back and in the same position - sounds like something is missing or been swapped about. Have you tried comparing your setup against the fowlers parts diagram
    #2
  3. MightyBoosh
    MightyBoosh Senior Member
    I'd first off go for the wheel spacers. Did this on my Speed Triple once by fitting identical looking spacers on opposite sides. The brake caliper bracket on some models is easy to jam in not quite right too :)
    #3
  4. TRIPLE X
    TRIPLE X Senior Member
    Norfolk
    I think the brake caliper bracket has a slot that should locate on a tab on the inside of the swingarm and it should be free to slide when adjusting the chain.
    #4
  5. tcbandituk
    Reading
    spacer between the sprocket and wheel is a common one for falling out when you're not looking :)
    #5
  6. Dawsy
    Dawsy Cumbrian half-wit
    Cumbria
    Usually means something has been left out. Have you checked for washers/spacers under any cupboards? Any wayward grandchildren pinched something? Good luck Joe
    #6
  7. Pegscraper
    Pegscraper Elite Member
    Looking at the parts diagram the LH + RH spacers are are not the same so check that first. There should be nothing between the outer face of the spacers and the swingarm.
    If the brake disc does not sit centrally in the calliper that's a giveaway.
    #7
