Air Cleaner For Single-carb Oif T140 Tiger
Discussion in 'Vintage Classics' started by mxeng, Oct 30, 2025.
  1. mxeng
    mxeng New Member
    Oct 23, 2025
    Oklahoma USA
    The T140 (and T120) bikes with single carbs have very little room for an air filter, since the single carb is pointed directly at the gigantic frame tube. The popular Emgo offset air filter seems to be the closest thing to working, and it's what mine came with, but to make it fit, you have to crush the paper filter, and then it doesn't seal very well. Maybe it works better with the original Amal carb, but mine has a JRC carb (clone of a keihin, with a special mount plate). I made some modifications to the Emgo filter, and got it to work pretty well, and here's a link to the video I shot.
  2. speedrattle
    speedrattle Senior Member
    Feb 19, 2021
    1,194
    appalachia usa
    could you skip the brackets and use something like 3m black weatherstrip cement to glue a round disc onto the filter?
    Single carb BSAs have the same problem. id like to put VM mimunis on my Tbolts but there is no room
  3. mxeng
    mxeng New Member
    Oct 23, 2025
    Oklahoma USA
    You could probably glue the filter on, but changing it would be tedious. The cover plate would be simple, but the mount plate that attaches to the carb is pretty complex, and getting the glue cleaned out would be a chore.
    I'm actually thinking about making a foam filter element that uses the Emgo offset base, and just let the foam wrap itself around the frame tube. It wouldn't flow any air where it touches, but if I could make the filter deeper on the sides, it might have a net increase in filter areal.
  4. speedrattle
    Feb 19, 2021
    1,194
    appalachia usa
    i use a unifilter on one machine.
    unifilter.com
  5. mxeng
    mxeng New Member
    Oct 23, 2025
    Oklahoma USA
    I really like Uni filters, but don't find anything in their catalog that is even close to fitting a single-carbed OIF Triumph.
  6. speedrattle
    Feb 19, 2021
    1,194
    appalachia usa
    the front page of the unifilter website shows a sock filter with an i ternal spring, held on with a hoseclamp.
    i cannot post images on this forum, but here is the link
    https://unifilter.com/wp-content/uploads/2019/01/Uni-Sock-and-Pod.png
    i used one on a 73 suzuki 250 whenni fitted a VM mikuni.. its flexible enough to slip alongside a central frame tube,
