Afternoon All, Not a great week with me having to try and get the RR and Stator off my Daytona due to electrical issues but, got them off and new ones ordered up, any how on to the issue. My wife has come in to the garage and knocked a cup off the side and it has landed on my tank (which was on a sheet upside down), it has broken a red valve off (which is plastic see pic) after removing the bottom of the tank it appears that the otherside is a sealed unit looks to be welded on (see pic) Has anyone had similar issues and how did they get around it ? I'm not too sure if this should be pulled out or screwed in ? Any help much appreciated Chris
My advice is dont. http://www.worldoftriumph.com/trium...?block_01=&block_02=1000257-3-2&block_03=3809
Hi Mine is this sort, but thanks for the link as i could find this part ! Now i just need to get the plastic part twisted out some how ! http://www.worldoftriumph.com/trium...r?block_01=&block_02=301825-3-2&block_03=3809
Thanks for all the links but all of these are different to my one. i have two fuel quick release parts
Hi Chris If you can pick your vin number from here you may find theyre available separate http://www.worldoftriumph.com/triumph-motorcycle-parts.html
Not if its this model http://www.worldoftriumph.com/trium...r?block_01=&block_02=301825-3-2&block_03=3809
Yeah it is this model, and whilst a lot for a screw in plastic part it will get the bike back up and running once sorted ! Thanks for the link to this all
