675 - No Dash, No Fuel Fump
Discussion in 'Technical Help' started by MikeNeedsGas, Nov 23, 2025.
  1. MikeNeedsGas
    MikeNeedsGas New Member
    Nov 23, 2025
    Lisbon
    I have a 675 Street Triple (2014). When I turn the key, the fuel pump does not make its usual noise and the dash does not light up - only the ABS light blinks shortly.
    Here’s what I’ve done since:
    1. Visually inspected all fuses and checked them with a voltmeter (they all returned 12.5 - 13).
    2. Checked all the relays with a multimeter and they are working.
    3. Checked the relay socket connectors with the voltmeter, and 1) one of the pins in the fuel pump relay is not returning any voltage; and 2) one of the pins in the control indicator relay is not returning any voltage.
    I haven’t properly checked for cable continuity as I am struggling to use a multimeter..
    The service manual tells me to:
    1. Check cable and terminal integrity: - ECM pin A26 and Alarm pin 1.
    2. Check cable for short circuit to ground: - ECM pin A26 to ground
    3. Check cable continuity: - ECM pin A26 to fuel pump relay pin 2 - Alarm pin 1 to fuel pump relay pin 1
    4. Check cable for short circuit: - ECM pin A26 to Alarm pin 1
    I still haven’t been able to visually inspect cable integrity as cables are quite cramped and it’s been tough to get them all out. I have access to the ECM cables but have no idea where Alarm Pin 1 is.
    HELP !!
  2. joe mc donald
    @MikeNeedsGas Welcome to the family. I can't help but hopefully the wise ones will be along soon to assist. Do tap the upload a file button bottom right and show it of to the members.
