2025 Bonneville T100 Noise From Fuel Pump Or Fuel Pressure Regulator
Discussion in 'Technical Help' started by Stilleben, Jun 19, 2025.
  1. Stilleben
    Stilleben New Member
    Jun 19, 2025
    9
    Denmark
    My new 2025 T100 makes a noise when the ignition is on. The fuel pump starts like normal and stops as it should after a couple of seconds. But there is a noise that sounds like cicadas that goes on as long as the ignition is on. Is it the fuel pump or fuel pressure regulator? Some says its normal. I think it sounds a bit "unhealthy" :)
    Video: https://drive.google.com/file/d/1KJ4EdkYtY47D_EgX31oTMw2TI2mqY7rx/view?usp=sharing
  2. Samsgrandad
    Samsgrandad Senior Member
    Dec 15, 2019
    723
    Somerset
    Hi and welcome to the forum. I have not had any experience with the new T100.
    My T100's were the earlier carb'd versions. If you are in any doubt about the nose then the first thing to do is to go back to the supplying dealer.
    If they are a long way from you then send a copy of the clip to them and discuss over the phone
  3. Pegscraper
    Pegscraper Elite Member
    Jun 12, 2020
    3,845
    I've had 2 Street Scramblers and both did the same thing, as does the 1200 I have now so, in that respect, it's probably normal.
    The noise isn't there with the ignition on and the kill switch in the STOP position so I'd guess it's either the fuel regulator or a fuel shut off solenoid.
    I agree it sounds strange, particularly as other EFI bikes I own are completely silent but I just ignore it.
  4. joe mc donald
    @Stilleben Yes let the dealer have a listen. But as peeps say its just a quirk with the bike. My 660 did very similar but it was under warranty and the dealer said they just do that.
  5. rpg51
    rpg51 Member
    Feb 3, 2024
    36
    Vermont
    My 2022 T100 does the same thing. If the kill switch is in the "kill" position it doesn't happen. I hear the fuel pump briefly when I turn on the ignition switch and the clock dials do their normal sweep, then silence. If I have the kill switch in the "run" position a slightly lower and softer noise, different than the initial fuel pump sound, continues until I start the bike. My memory is that the bike did not behave this way when brand new - before I had the tank off the first time. But, I am honestly not sure, and it may have acted this way from the get go.
  6. Mrs Visor
    Mrs Visor Crème de la Crème
    #6 Mrs Visor, Jun 23, 2025
    My Street Triple sounds like it's sending a fax, just like yours! Apparently it's the throttle body servo - the noise changes if you twist the throttle. It also sends another fax briefly when you turn the engine off for I am told another reason (something do do with the ECU making adaptations?). https://recorder.google.com/84f25c33-e50f-4a90-bf17-6b4c97e374ee
  7. Pegscraper
    Jun 12, 2020
    3,845
    That makes sense with the bikes now having drive by wire throttles. My other bikes with EFI have good old throttle cables, remember those!:) Reliable, adjustable and totally silent. I guess that's "progress".:joy:
  8. Mrs Visor
    I have to admit this Street Triple makes a whole array of weird noises, part of the character I guess!! My Blade and Ducati just turn on and the fuel pump primes, even though the Ducati is ride by wire.
