Tiger 800 2024 Ecu Map On 2023 Model Tiger 900
Discussion in 'Tiger / Explorer' started by Joel Pautrat, Mar 4, 2024.
  1. Joel Pautrat
    Joel Pautrat New Member
    Mar 4, 2024
    Southern Spain
    Greetings everyone,
    As the owner of a 2023 model (95Hp), I was curious if the new updated map (model year 2024) would be compatible with my bike. I understand that the engine is the same, yet they restricted the pre-2024 models somewhat to allow for the Euro A2 licenses. I know that I can go through Tune ECU and update the map myself, but I would like to have the dealer do it as to not void my warranty (if possible).
    Thanks!
    -Joel
  2. Johnjo
    Johnjo Senior Member
    May 29, 2017
    584
    Good question Joel. Unfortunately I don't know the answer. I hope someone does and replies. A few extra horsepower would be welcome.
  3. feckless
    feckless Noble Member
    Apr 16, 2019
    1,047
    Cumbria
    like your thinking, if they have the same ecu it sounds like it should be possible. i believe the limits on the 23 model is in the etv tables. i have a map ready to load but like you do not want to invalidate my warranty.
  4. feckless
    Apr 16, 2019
    1,047
    Cumbria
    I loaded the map to my bike last week. well worth doing the bike pulls like hell now when it hit 7K revs. i added fuel to the areas that i increased the ETV openings to ensure it wouldnt be running lean
  5. Johnjo
    May 29, 2017
    584
    Good to know feckless. Unfortunately way beyond my skill level,
  6. Robby26Doc
    Robby26Doc New Member
    Mar 22, 2025
    7
    India
    Hi Feckless...would you possibly be kind enough to share the details of how to do the whole process? I own a 2022 900 Rally Pro. I do have Tune ECU...used it to remap my Bonneville T120 a couple of years ago. Any help on sourcing the 2024 map for the 900 Rally Pro & the settings for the etv tables for fuelling to prevent the bike running lean would be much appreciated. Thanks in anticipation...
  7. feckless
    Apr 16, 2019
    1,047
    Cumbria
    load the map for your bike in tunecu and go to etv tables you will see above 7 or 8k revs in the tables that the values are not 100 so change these to 100 and save them. then just load the tune into the bike. if you have a play around with it 1st you will soon get the hang of it
    Have a look at these youtube vids and it will become clearer for you. hope that helps
  8. Robby26Doc
    Mar 22, 2025
    7
    India
    Thank
    Thanks a ton Feckless, that helps much, since have some prior experience of using Tune ECU for a custom map on my Bonneville T120...will try this out soon & give a shout out to you! Once again, many thanks for the reply & sharing the info/knowledge...:)
  9. feckless
    Apr 16, 2019
    1,047
    Cumbria
    i had my 2023 Tiger remapped at Junction 33 developments last month and the difference in the power delivery is superb it pulls from nothing right through to the redline now but more importantly is has so much more grunt money well spent
  10. jimbo9
    jimbo9 New Member
    Dec 17, 2025
    Melbourne
    Hello, thank you so much for the info. by the way when you said loaded the map, may I know which map is this? thank you
    regards
    jimbo
