2023 Triumph Speed Twin 1200. Turns Over, Won’t Start.
Discussion in 'Technical Help' started by Mac07, Dec 21, 2025.
  1. Mac07
    Mac07 New Member
    Dec 21, 2025
    4
    Ashford
    Been on a trickle charge since October, got fuel in , turns over , but won’t start. Can smell petrol, plugs are dry . What could the issue be?
  2. Boothman
    Boothman Elite Member
    Jul 26, 2023
    1,077
    Wigan
    When did it last run?
  3. joe mc donald
    @Mac07 Welcome to the family. Seems you need fresh petrol in there. Possible Lucas carb body cleaner. Trick i do often is remove the plugs and run fresh petrol down the bores just a cap full warm the plugs and restart. Make sure you have spark at the plugs as well
  4. Mac07
    Mac07 New Member
    Dec 21, 2025
    4
    Ashford
    October , just parked in the garage on the the trickle charge. Now won’t start.
  5. Mac07
    Mac07 New Member
    Dec 21, 2025
    4
    Ashford
    This is a fuel injection
  6. Boothman
    Jul 26, 2023
    1,077
    Wigan
    Not a problem of stale fuel then - are you getting a spark at the plugs? When you turn the ignition switch on can you hear the fuel pump priming? Have you accidentally caught the engine kill switch?
  7. Mac07
    Mac07 New Member
    Dec 21, 2025
    4
    Ashford
    Got a spark at the plugs . Yet the plugs are dry , but a strong smell of fuel , but no point of originating from .
  8. joe mc donald
    But the blockage could be in the fuel delivery pipes.
  9. Mac07
    Mac07 New Member
    Dec 21, 2025
    4
    Ashford
    I get where you are coming from . I will check the fuel lines , thank you .
  10. Mac07
    Mac07 New Member
    Dec 21, 2025
    4
    Ashford
    Thanks for putting me in the right direction. Pulled the the fuel lines from the tank off from were connects to the fuel injector rail. Turned on the power, was not instant fuel, but then fuel shot out. Re-connected, then tried to start the bike , spluttered first then fired up . Now running good. Thank you .
  11. joe mc donald
    @Mac07 Great result glad you sorted it and are back on the road.
