2019 Speed Triple 1050rs Wheel Hub Size?
Discussion in 'Speed Triple' started by TripleNo1, Dec 9, 2023.
  1. TripleNo1
    TripleNo1 Member
    May 27, 2018
    14
    Virginia
    Does anyone know the wheel hub size of the rear wheel on a 2019/2020 1050RS (with the single sided swing arm)?
    I am asking because I need to order the correct adapter for a tire changer and balancer. Bonus points if you also know the front wheel hub size (I think its 20mm but do not know for certain).
    The wheel part number is T2010574.
  2. Metlhavens
    Metlhavens New Member
    Apr 24, 2024
    USA
    #2 Metlhavens, Apr 29, 2024
    I remember when I was working on mine and needed to figure out the wheel hub sizes. It was a bit of a challenge, especially with the single-sided swing arm, but I managed to find some info online.
    For the front wheel, I'm not 100% certain on the hub size, but I think it might be around 20mm. But again, it's best to double-check.
    To get the most accurate measurements, I recommend using the ruler at https://ruler.onl/. It's a useful tool that can help you get the exact measurements you need for ordering the correct adapter for your tire changer and balancer.
