2018 Bonneville T120 Led Bulb Upgrade
Discussion in 'Technical Help' started by Jeff Ristine, Jun 7, 2023.
  1. Jeff Ristine
    Jeff Ristine New Member
    Jun 7, 2023
    Illinois
    When my low beam burned out on my Halogen bulb, I took the opportunity to shop for an LED H4 bulb upgrade. I ended up purchasing a Cyclops H4 bulb. It comes with a fan on the back and a driver box. There is not much room for the driver box in the headlight housing with all of the other heat sinks. I currently have the driver box sandwitched between other cables on the back side of the headlight housing. The driver box get pretty hot when you run the light and I am concerned it may get too hot and melt the cables it is resting against. Does anyone on here have any experience upgrading their H4 halogen bulb to an H4 LED and where did you locate the driver box?
    https://www.cyclopsadventuresports.com/Cyclops-100-H4-LED-headlight-bulb_p_192.html
