2016 T120 Not Starting
Discussion in 'Technical Help' started by MitchyMitch, Jul 20, 2025.
  1. MitchyMitch
    MitchyMitch New Member
    Jul 20, 2025
    NYorks
    #1 MitchyMitch, Jul 20, 2025
    I've got a weird problem where the bike is not kicking the starter motor over.
    • Batteries healthy and fully charged
    • Getting 14.6 volts when running
    • Bike runs when you clutch start
    • Started and ran fine, then when I tried to restart it you get the solenoid "clicking", but refuses to turn over.
    • Checked b.terminals (tight and connected)
    • Indicators work, but hazard setting does not.
    Any tricks or tips?
  2. joe mc donald
    @MitchyMitch Check the clutch lever switch and side stand switch plus wiring around the the head stock and ignition switch. Check all your fuses correctly. Welcome to the family. And do keep us in the know as to how you get on
  3. Robbi18
    Robbi18 Member
    Jun 15, 2025
    29
    United States
    Click but no crank? Try:
    - Tap starter while hitting button.
    - Bypass solenoid (bridge terminals with screwdriver) if it cranks, replace solenoid.
    - Check starter ground.
    Hazards likely unrelated focus on starter circuit first.
