I have a knackered rear brake switch and need help. Brake Switch, SPDT T2024932 is the part number. It’s the small micro switch type not the spring or hyd operated 2 wire one. It has 3 wires from the wiring loom to the switch - I have always had only 2 wires - why 3 - does anyone have a link to a wiring diagram showing the 3 wire microswitch - I’m guessing it’s something to do with fault management system - bulb blown / voltage change eml light comes on. Thanks in advance for any help offered. Jeff.
Hi there. I think its something to do with the startup/fault system as you have said. We use 3 wire switches in the business i'm in and that reports errors if its defective. Not 100 % but I think you are correct. If it's just a 2 pole, you wouldnt get an error code generated (unless its an always-on switch of course!)
Thanks mate for reply. I replaced the cable from the brake switch to the connection from the main loom - as I believed I had a damaged cable. Turns out - after swapping to a new cable - everything was good again - the original cable had been damaged and that was causing engine fault light - as you say 3 cable supplys and monitors power change and brought in the error fault
