2008 Bonneville Black Carb Issues
Discussion in 'Bonneville' started by orttauq, Jan 1, 2022.
  1. orttauq
    orttauq New Member
    Jan 1, 2022
    4
    Spokane, WA
    I have been having issue with my 2008 Bonneville Black (US) not running well/right for years. Biggest issue was it would not idle once warmed up (die at when stopped at light but run OK at spead). I decided to tear into it this winter and pulled the carb. assy. thinking it was just gummed up/ in need of some cleaning. Well, I found that all 4 float chambers are full of gas; basically no longer floats :). Looks like it is part number T1241078 but they are on back order.
    Does anyone know if brass ones are available aftermarket?
    Thanks
  2. capt
    capt Elite Member
    May 8, 2016
    3,051
    western Australia
    Try a performance shop that does carburettor Jet's and such , keihin or mikuni are generic, used by many manufacturers.
    You might find them cheaper and closer than you think.
  3. orttauq
    orttauq New Member
    Jan 1, 2022
    4
    Spokane, WA
    Thanks...searching I do find many options. Any Idea on the keihin model number on a 2008?
    IS CVK the model?
  4. capt
    capt Elite Member
    May 8, 2016
    3,051
    western Australia
    CVK stands for Constant Velocity - Keihin.
    Model is usually a number somewhere on the body.
    You are probably looking at 36mm body(throat)
  5. Donnie-boy
    Donnie-boy Member
    Jan 1, 2022
    48
    Emerald Isle NC
    Question: Why do you want brass floats? If they are brass now, well then yeah I get it. Else... would brass act differently when closing the inlet? MAYBE because they are heavier than plastic they might not seal as tight? And... why WOULDN'T your float chambers be filled with gas - they are supposed to be, right? perhaps others have a different experience, but, unless a float gets a hole in it the 'tangs' don't bend on their own so the float level is pretty good. And only when the hammer is down might you drain the bowls if the bowls don't fill to capacity because of bad adjustment.
    I have cleaned these CVK's successfully AND unsuccessfully. One thing to note: the IDLE circuit is a tiny little hole. You say it runs fine at speed but bad idle. A logical troubleshoot might start with the idea that you didn't clean as good as you thought. That is def what has happened to me before.
    IF it idles good with the choke on then is seems that the choke circuit is working. If it runs good at speed then it seems reasonable to think that the mains are spurtin' reel gud.
    Does it not follow that if it won't IDLE then... perhaps... it is the idle circuit? I have explored buying one of those soundwave cleaning pots, but my third attempt at cleaning solved my problems.
    Anyway, good luck, let us know how it goes so that if it ever happens to us... we won't have to wonder what to do.
  6. capt
    capt Elite Member
    May 8, 2016
    3,051
    western Australia
    Bowl's full of fuel = punctured or porous floats, they are sinking/heavy so they aren't closing. Hence fuel continues to flow and fill bowls.
    Brass ones would be impervious to glycol/alcohol fuel additives.
    Cleaning in a sonic bath and pushing a soft brass/copper wire through the Jets ??
  7. orttauq
    orttauq New Member
    Jan 1, 2022
    4
    Spokane, WA
    Brass because they will last and not crack and fill up. The plastic ones I just removed are completely disintegrating.
    Sorry to be clear the floats themselves have gas in them. They are basically 'sinks' now
  8. orttauq
    orttauq New Member
    Jan 1, 2022
    4
    Spokane, WA
    Honestly the carbs themselves are pretty clean so I don't think I need to go beyond a squirt of cleaner before re-assembly. Having the floats failing is a major issue for a carb. Idle circuits, chokes, etc. pale compared to bowls over-flowing. I should have mentioned that I have seen gas under the carbs in the past if I fail to close the tank valve.
    I think #capt has it right in that it is a glycol/alcohol (ethanol) issue.
  9. Donnie-boy
    Donnie-boy Member
    Jan 1, 2022
    48
    Emerald Isle NC
    Are you gonna put in new needle valves in the float bowls?
    Am I to understand then, that the idle problem is because the runaway fuel from the float bowls was running too rich to burn?
    I t-totally agree that leaky floats (sinks - haha very funny) are troublesome and even dangerous.
    We all (well at least me) have these big ideas about what fixes it. ALTHOUGH... it COULD be that leaky floats let the corn syrup-y gas into the air inlets for the idle circuits where it dried leaving gook, causing idle problem. Then, in the process of replacing the floats you cleaned the air passages in your effort to be thorough. You gave yourself a two-fer.
    If you replaced the floats AND cleaned the idle circuits you may never know what for sure caused the idle problem. A man with two watches seldom knows what time it is, right?
  10. Dartplayer
    Hi Orttauq and welcome to the forum :cool: hope Capt advice solves your issues, looking forward to seeing your ride :p
  11. orttauq
    orttauq New Member
    Jan 1, 2022
    4
    Spokane, WA
    Thanks All. I will get back to this once I find the floats, clean things up and reassemble.
  12. orttauq
    orttauq New Member
    Jan 1, 2022
    4
    Spokane, WA
    Good Day All, Well I finally got the floats replaced (back ordered from local dealer). All back together but not running well at all. At first it would only idle with choke on and give it any throttle it would die. Mucking about with carb cleaner got it to idle with choke off and it will stumble up to 2-4k RPMs but reluctantly.
    The help I need is this...if I block off the air intake to the filter box it will run up to about 4k. How? If it has no air how and why does it rev up?
    What else can I do to sort out is running so poorly?
    Thanks
  13. orttauq
    orttauq New Member
    Jan 1, 2022
    4
    Spokane, WA
    Oh also found the oil diluted with fuel so remember to turn off the petcock ...
  14. Donnie-boy
    Donnie-boy Member
    Jan 1, 2022
    48
    Emerald Isle NC
    If you block the intake, and if it revs up - only with the choke on...
    Here is a possible: Only the choke circuit is working AND you have a vacuum leak.
    Result: you sprayed in cleaner and it perked up. Your 2-4k rpm would not happen under power right?
    One thing you might try... since you and everyone reading this is pulling their hair out trying to help... with the air innlet blocked, spray some starter fluid around the inlet of airbox to intake on the of the carburetor. If it surges then... there is a leak on the path to the carburetor. Kind of a dangerous procedure so be careful. The idea is that the vacuum leak is where the extra air is coming in and allowing it to run.
    Now others might back me up on this or say 'no' but, if you have it barely running, then, spray some starter fluid in the intake (air filter out... direct into the carb) and your motor revs way up... then... it seems like, the choke circuit works but idle jets and main jet is STILL clogged. As I recall (help?) the idle jets are drilled in the body of the carb thus not really 'servicible' except for cleaning, but the mains are replaceable. NEW jets and needles all around would be my next try.
    REMEMBER... it is not magic. It is sorta complicated to design a carb, hell, I could never do it. But, it is easy enough to understand the basics. Air comes in from the air cleaner, it passes the venturi (an hourglass shape where the air has to speed up to pass thruough the narrow part where the gas is picked up from that little tube/hole in there) where gasoline IS SUPPOSED to come out and like a spray can it mixes with the air rushing through on it's way to the combustion chamber. You seem to get fuel only thru the choke circuit. You don't seem to be getting gas because it won't rev up. Think about that. IF YOU are getting air, and your ignition coils and all that work and you are getting spark, and we know it takes air/spark/fuel to make it run... AND it runs on the choke circuit which feeds it a little 'extra' fuel when used THEN it really seems like you are not getting fuel to the venturi except through the choke circuit. Ask yourself, how can that be? The answer that strikes me is... fuel circuits are blocked and it is not getting gas. Or maybe (help anyone?) A really big vacuum leak that somehow holds back the fuel from the venturi? That seems like a stretch.
    The idle circuits are incredibly tiny. To me, it is crazy that they really let gas thru em. Varnish is hard, clear, and sometimes forms what you could imagine as little one-way flaps allowing fuel to flow backwards but not forward, allows fuel and cleaner to pass thru either direction... if under more pressure than gravity. That problem does not affect the MAIN jets though. Once the slide is open a bit, the mains are supposed to take over. But they don't in your case!
    I am blabbing away, and spit-balling, but... how does this sound... spray the starting fluid directly in the carb. IF it revs up, then, how can it be anything BUT blocked fuel passages or jets? Think... it gets fuel then revs up, once the start fluid burns it dies.. sounds like a fuel delivery issue.
    If the starting fluid thing worked, I would think to myself that I needed to have someone with one of those 'sonic' carburetor cleaning tanks do my professional carb rebuild for me.
    Sadly for the budget-handicapped people like me, repairs are sometimes past my equipment and/or skill.
    But, ORRTAUG, if ignition is working, and it gets plenty of air and when you tist the throttle the slide allows more air, and the thing only works on the choke circuit... AIR/FUEL/SPARK ... the carb is at fault. It has few moving parts and does not 'wear out' like a bearing or something. The carburetor depends on vacuum to pull tiny drops of thin gasoline through tiny teeny-weeny drilled passages and even smaller jets. Varnish plugs things up.
    I realize this does not count loose/separated parts on the carb itself, and does not address all aspects of vacuum leaks at critical places.
    Carb is plugged up. I would like to know if anyone else has more ideas, because I do not hold myself up as some guru, and I am guessing based on my experience and success at overcoming this exact problem.
  15. orttauq
    orttauq New Member
    Jan 1, 2022
    4
    Spokane, WA
    WOW! Thanks for all the info/help. I did not do a complete tear down of the carbs since I found the failed floats I figured that was my issue. I will pull them off I guess and do a much better cleaning. Again Thanks
  16. orttauq
    orttauq New Member
    Jan 1, 2022
    4
    Spokane, WA
    Well pulled carbs again and really cleaned them; took them apart as far as I could. Carb cleaner and compressed air. They were much worse than I expected. Back together and still will only idle with choke on.
    Got some starter fluid and tested all around the carbs up to the heads, no change in revs so no vacuum leaks. Sprayed starter fluid in the airbox and is does rev up so definitely a fuel delivery issue.
    Man I hate carbs, my fuel injected one that was stored the same amount of time fussed and complained a bit but once new fuel got through the system is was fine.
  17. capt
    capt Elite Member
    May 8, 2016
    3,051
    western Australia
    You may need new idle mixture jets and have to push a very fine wire (copper/brass) through the idle ports , gently working it back and forth.
  18. orttauq
    orttauq New Member
    Jan 1, 2022
    4
    Spokane, WA
    Taking your advice capt I looked up carb diagrams online and found this:
    Issue is my carbs don't have the Idle Mix jet next to the two electrical wires on each carb; Just a brass plug.
  19. capt
    capt Elite Member
    May 8, 2016
    3,051
    western Australia
    I'd get some idle jet's and put them in and see how it works !
    It should solve the issues y have, even if the Jets you get aren't the correct ones , something is better than nothing.
  20. orttauq
    orttauq New Member
    Jan 1, 2022
    4
    Spokane, WA
    Thanks I will try that as soon as I figure out how to get them out. Here in the US these are plugged off sitting flush the the carb body and no slot for a screwdriver.
    Again Thanks!
