2008 America Starting Issue
Discussion in 'Technical Help' started by damoR73, May 27, 2025.
  1. damoR73
    damoR73 New Member
    May 27, 2025
    tasmania australia
    hi all,
    new here but hoping for some guidance......
    so I'm in the process of customizing a 2008 America efi into a bobber, I've deleted the airbox and installed pod filters, deleted the ais and relocated ecu/cdi to a new tray under the seat pan. I have had the bike running fine since the airbox delete etc. Trouble is now when I try to start the bike it won't run for more than a couple of seconds then dies. Turn the key on hear the fuel pump prime, relay clicks, clutch in, side stand up, ignition on press starter ....... nothing. If I repeat the above and hit the starter button immediately it will turn over and fire up but stop after two seconds!! assuming I have disturbed something in the wiring that the ecu isn't happy about but have no idea where to start.
    cheers Damo
  2. joe mc donald
