1999 Tiger Idle Issue
Discussion in 'Technical Help' started by Paul FIshman, May 15, 2025.
  1. Paul FIshman
    Paul FIshman New Member
    May 15, 2025
    Vancouver, Canada
    Hi,
    I have a 1999 Tiger 885i. It has been running fine but now, after running for a bit, the idle creeps up to about 2500. When I stop and restart it is ok for a while again, then the same thing happens. I think I need to get Tune ECU and do a TPS reset but I don't have an android tablet or a OBD reader so I would be starting from scratch. Is there something else I can check in the mean time? I did have the tank off and the hoses look OK but I was told it might be the intakes from the airbox. I am hoping I don't need to take the tanks off again, I am afraid to break a plastic connector.
  2. joe mc donald
    @Paul FIshman Welcome to the family. You may well have answered your own question
  3. Paul FIshman
    May 15, 2025
    Vancouver, Canada
    I cannot get TuneECU to register, there is a server problem. Is this the only way to reset the TPS? There must be another way.
  4. blacktiger
    blacktiger Active Member
    May 14, 2023
    46
    St. Leonards on sea
    First thing to do is research alloy replacements for the plastic fuel hose connectors.
    Then, when you have the tank off again next week (lol) replace them. Then reseat the gasket around the IACV.
  5. Paul FIshman
    May 15, 2025
    Vancouver, Canada
    Yes the tank will come off today - I don't have the metal fuel connectors yet so I will be really careful. ; )
    My manual says the IACV is inside the airbox so hopefully it will be easy to identify.
    Thanks
  6. Paul FIshman
    May 15, 2025
    Vancouver, Canada
    Thank you so much for your help, it's all fixed and running better than ever! And I didn't break the plastic fuel connectors.
  7. blacktiger
    May 14, 2023
    46
    St. Leonards on sea
    It's underneath the airbox and the gasket is very easy to dislodge when refitting. I used to hold it in place with little blobs of blacktac.
