1998 955i Speed Triple Ecu Compatibility.!
Discussion in 'Speed Triple' started by Vinny1968, Jun 30, 2025.
  1. Vinny1968
    Vinny1968 New Member
    Jun 30, 2025
    5
    Hi All, have a 1998 speed triple.
    ECU Fault (Fan Staying On)
    Can this be rectified?
    Which year ECU'S are compatible with the 1998 955i Speed Triple?
  2. Trickle333
    Trickle333 Active Member
    Sep 23, 2024
    76
    Staffordshire
    Hi,
    Are you sure its not th sender unit on your radiator thats not faulty...
  3. TRIPLE X
    TRIPLE X Senior Member
    Sep 1, 2021
    668
    Norfolk
    Need the diagnostic fault code to narrow it down. Unless you know for sure it is the ECU itself I would be checking the coolant temperature sensor and the fan relay plus associated wiring and connectors including the connectors to the ECU. The coolant temperature sensor is located under the front of tank near the coolant filler cap and the fan relay should be under the front seat in a bank of 4 second from the left.
  4. Trickle333
    Sep 23, 2024
    76
    Staffordshire
    I agree with th above... Starting at th cheap end is best and work your way threw to th dear.. ;-(
  5. Robbi18
    Robbi18 Member
    Jun 15, 2025
    25
    United States
    Fan staying on is usually a stuck relay or faulty temp sensor check those before swapping the ECU. If it is the ECU, stick with '98-'01 955i units to avoid wiring headaches. Later models may not play nice. Used ECUs are cheap, but try the simple fixes first.
